Old 08-28-2009, 07:47 PM   #1
supradaddy0803
supradaddy0803's Avatar
I agree with Nate crank walk sucks and downgrading the clutch isnt going to help. You have done the damage now and seeing as the 7MGTE thrust main bearing is 3 peices on the top and bottom you have probably wore it out or just broken it. So if you take out the clutch then it will still do it. Sounds like you gonna have to look into doing the bottom end. But look into it there are way to check to see if the thrust bearing is bad but from what your telling us sounds like it I am sure if you ask any of the guys with high Horsepower they will tell you they have either run into this problem or were warned first and did all the stuff to the bottom end before getting that type of clutch.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
