Old 08-20-2009, 09:22 PM   #1
robertsws
robertsws's Avatar
robertsws is on a distinguished road
Smile
OK, I pulled the timing belt cover and the CPS and then double checked their alignment with TDC, Put it all back together and it started right up.
Of course now I have a really bad knock. Checked my valve clearances and 18 out of 24 are off anywhere from .001 to .003. I'm ordering new shims and then I will see if that took care of the knock.
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
robertsws is offline   Reply With Quote
