Thread: Engine swaps
Old 08-20-2009, 12:36 AM   #3
shiftysupra
shiftysupra's Avatar
shiftysupra is on a distinguished road
well then i understand your not looking however i'll help you.
1st. the engines are completely the same besides the block on the 7mgte has piston squirters. obviously the ecu and harness as well as others..
2nd. the flywheel for the gte is different than the ge.
3rd. i can tell your lying about searching because if you put 'toyota supra na to turbo conversion' in google you will get this site at the top...
http://www.4cefed.com/
i know your anxious to get the car running but you need to learn to do your research or your swap and car owning experience is going to be hell. plus no one like doing research for people unpaid
good luck on the swap let us know how it goes.
p.s. the reason you cant find any responses on most threads are because like you, did not do their research because this stuff is posted everywhere. another forum you may research on that has so much info is supramania.com. and for any tech related issues please refer to http://www.cygnusx1.net/Supra/Librar...3/default.aspx this is your bible and it should be used when you run into an issue.
shiftysupra is offline   Reply With Quote
