Old 08-18-2009, 05:49 PM   #16
shiftysupra
shiftysupra's Avatar
shiftysupra is on a distinguished road
Originally Posted by Igknyte View Post
i did the simple test with a paper clip into the diag port and code 52 knock sensor .. but thats all that showed up..
fix your nock sensor... why do people like you always think that it's not important and it must be another problem? the nock sensor can cause many issue up to engine failure. once you fix the code, if the problem is still present then move on to the next possibility. it's called trouble shooting. use your critical thinking skill man. if you start skipping things your going to have a world of problems.
shiftysupra is offline   Reply With Quote
