Old 08-14-2009, 08:44 PM   #2
oregonjoe
oregonjoe's Avatar
Default 7MGE Rebuild - Block Removal
Well, since the block has to come out – in comes the hoist. I put a jack under the oil pan and transmission and unbolted the bell housing and engine mounts. I bolted the chains to the engine mount holes since I did not want to use the head bolt holes if one of them was already cracked. Balanced just fine and lifted right out by my self. This engine lift is a rally great tool you only get to use a few time in your life but it really works.
Now I get to look at the clutch and flywheel. Going to need some resurfacing and the clutch disk was worn to the bone – time to replace along with the throw out bearing and pilot bearing
Got the engine on the stand and upside down to remove the oil pump. After unbolting one bolt it would not budge so I removed the pump drive shaft still not budge. Figured was a pressure fit so used a screw driver on the block to pry it off.
Next it was time to pop the pistons. The cylinders had no ridges so they came out really easy. Bagged each one in numbered bags. The rod bearings looked a little worn but were very even with no hat spots. The crank looked very good too so hopefully it can be reused. I am going to take it to the shop in the block to have them check tolerances and we will see what the verdict is on the head bolt hole crack and crank. Cross my fingers.
A week of nights and two cases later
