Old 08-05-2009, 11:15 PM   #1
86.5 7MGE
86.5 7MGE's Avatar
Talking
Originally Posted by 87mk111 View Post
I blew that same line on my supra. You'll need to replace it. After u replace it, pull ALL wires of ur spark plug wires. There will probably be coolant in all 6 of the holes, it looked like it was only in the #2 and 3 on mine, but they were all full. Next, take a shop vac and suck the water out. Then put thw wires back in, top off the coolant, and start it up. Make sure to check for leaks after u start the car back up.
Ok thanks I found a small pin hole spraying out from the hose going over the back side of the engine will be replacing it ASAP.
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
