Old 07-30-2009, 02:01 PM   #1
87mk111
87mk111's Avatar
I blew that same line on my supra. You'll need to replace it. After u replace it, pull ALL wires of ur spark plug wires. There will probably be coolant in all 6 of the holes, it looked like it was only in the #2 and 3 on mine, but they were all full. Next, take a shop vac and suck the water out. Then put thw wires back in, top off the coolant, and start it up. Make sure to check for leaks after u start the car back up.
