Old 07-08-2009, 01:05 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Durandal View Post
So I've been trying to troubleshoot why my car sometimes has problems starting even though it turns over fine. I was going to check plugs, coil packs, igniter and possibly fuel filter. When I popped the protective cover off of the engine I noticed that one of the hoses running from valve cover to valve cover was cracked and showed signs of leaking a liquid substance. I have a general idea of what those hoses are for but what sort of problems would something like that cause. I am going to replace it asap.
Thx
It's just a PCV hose...which has nothing to do with starting unless your PCV valve is bad. I agree with your plan to check the plugs, and fuel filter. The coil packs I'd only check if your Supra has more than 100K miles. Also add checking the air filter to your list, and run some fuel injector cleaner too (if you haven't recently).
Life begins at 30psi.
