Old 06-30-2009, 03:21 AM   #1
btwilson86
Super Moderator
btwilson86's Avatar
Fuel pump does NOT turn on when the key is just in the on position. It only starts pumping once the engine starts turning over.
It sounds alot like a timing issue... you said that the timing is spot on. Are you 100% positive that the cps was placed on the compression stroke and not on the exhaust stroke?
