Thread: 1jz-gte
Old 08-13-2005, 07:21 AM   #1
daiagaru2
daiagaru2 is on a distinguished road
you will need to lenghthen the ecu's wiring harness if you are swaping in a 1jz-gte to a left hand drive supra,you'l need to get a jza-80 supra mk4's power steering line and thottle cable.get a complete half cut so you have all the parts you will need for the swap excapt what i mentioned above.you are right about the later cross member,you need one.you'll need a new tachometer,boost gauge and plenty of time and tools.a complete half cut should come with rear sub frame and differential too.good luck. 1jz power!
daiagaru2 is offline   Reply With Quote
