Thread: Car wont start
Old 08-12-2005, 05:36 PM   #1
daiagaru2
daiagaru2 is on a distinguished road
yeah check everything they told you to check,wires,battery.engine cranks realy slow,starter seems to be good,however the charging system may be the culprit if all of your wire leads are good.look at the alternator it may not be charging the battery system enough to start the car after you've shut it off.if the security system has been tripped the starter cut of is activated completely cutting off current to the starter.if the starter is turning slowly then the secirity system has not been engaged.
daiagaru2 is offline   Reply With Quote
