Thread: 1.5jz question.
Old 06-02-2009, 12:35 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Javier Wilde View Post
First of all hello.
I got a toyota soarer 1jzgte, and i bought a 2jzge very cheap, and my question is can i put the 2jzge crankshaft, rods and 1jzgte pistons in my 1jzgte block, so i dont loose the squirters???.
Does anyone knows any link with that?.
Thanks alot.
Javier.
1) I don't know for sure, so please double-confirm elsewhere
2) I don't think you can do what you describe - from what I understand, the 1jz-gte is the same bore with a shorter stroke (which is why it's only 2.5L).
To me, you should consider doing it the other way...take your 2jz-ge block to a machinist and ask him to drill holes & tap boltholes for the 1jz-gte oil squirters.
Life begins at 30psi.
