Old 05-22-2009, 01:37 AM   #1
mirage83
There's a lower radiator hose and probably a drain valve on the bottom of the radiator itself. If the hose is loose or split it could leak, or the drain valve might not be closed completely and allow the water to leak out.
Check for both, as coolant loss is a big no-no with a 7M.
