Old 05-20-2009, 10:02 PM   #1
dunewarz
dunewarz is on a distinguished road
Most likely it's a timing problem. Check you cam position sensor. Check you timing with a timing light. Make sure you also check you tps as it can cause hesitations and bogging at low rpms if not in the correct position.
dunewarz is offline   Reply With Quote
