Thread: supra or 300zx
Old 05-15-2009, 03:40 AM   #1
justin1642
justin1642's Avatar
justin1642 is on a distinguished road
the stock hg was torqued at 55lbs or so from factory and some just retorque the stock head bolts but most use arp studs n bolts and retorque at 75lbs. other than that its a solid motor. the 2jz takes some modification to get it in a mk3 the other option is a 1jz that drops in if you have the right motor mounts (89-92)
justin1642 is offline   Reply With Quote
