Old 05-14-2009, 03:32 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by m0t0xk1d View Post
is it possible? i was looking to get a supra but with prices so high of a twin turbo a was thinking of getting a non turbo. i was wondering if i could later but twin turbos on it or could i only put a single on it?
Yes, you can turbo it later (either twins or a single), but for twins you'd need to change the head. Like Curtis says, there'd be limits if you single turbo'd the 2jz-ge due to the higher compression pistons...probably about 400rwhp or so max. Even if you did all of this (including the fuel system and ignition systems you'd need to beef up to support this level), you'd still be way behind what you'd have with a full mkiv tt because of the braking system, the suspension, transmission, differential, etc., etc. In other words, the mkiv tt is a LOT more than just an n/a with turbos.
Life begins at 30psi.
