Old 05-14-2009, 12:15 AM   #1
Curtis
Curtis is on a distinguished road
Originally Posted by m0t0xk1d View Post
is it possible? i was looking to get a supra but with prices so high of a twin turbo a was thinking of getting a non turbo. i was wondering if i could later but twin turbos on it or could i only put a single on it?
Okay man, check the name of the engine, if its a 2jz-GE than its a non-turbo, meaning the supra is a downgrade. A GE engine will have high compression pistons, (which is a bad thing, turbos add alot of compession meaning you'd blow something) your also looking at changing your head, and alot of other stuff..
A 2jz-GTE (turbo engine) has completely different cylinder head, oil squirters to cool the pistons. The GTE supras also had better abs braking system, transmission, rear differential, ignition and starter, ecu, suspension, and more... The non-turbo version (GE) is a big downgrade, and your looking at alot of work and money to add turbo's to it.
IMO i'd save up for a turbo supra, or buy a cheap supra then buy an engine for it (2jz-gte).
Hope that helps.
they.call.me.curtis
Curtis is offline   Reply With Quote
