Old 05-13-2009, 02:47 AM   #1
midwestmk2
midwestmk2's Avatar
unless you have previous experience with doing an entire engine swaps like this(ie=ECU,custom harness,cooling,money,time,and tuning) i would just have the 5m rebuilt..You can always convert the 5m to a turbo later if you still want to go boosted.. It is easier to convert it than it is to swap a 7m in there..If you do go 7m good luck on the swap and ill answer any questions if i can..
