Old 05-13-2009, 12:02 AM   #1
Vacationtime247
Fixing the throttle cable isn't that hard to fix, but might be difficult to find a replacement. When I did my 350 / 700R4 swap I went aftermarket. You'll need to remove the bolts that hold the gas pedal down. The bolts that hold the throttle cable linkage to the firewall and remove the wire from the throttle body mechanism. It's not hard to do, just time consuming.
VT247
Originally Posted by cgreiner View Post
I gunned it and squealed the tires a bit. Then...all of a sudden...pedal to the floor...the car went to idle. I had snapped my throttle cable :-(
At least I know what my next project is, and my next qeuestion
- How much of a pain will that be to fix ?
