Old 05-06-2009, 05:58 AM   #1
dunewarz
dunewarz is on a distinguished road
I once converted a 300zx auto into a manual. First of all you need a manual tranny, clutch master cylinder, clutch pedal, you might need to cut the brake pedal a bit to allow room for the clutch pedal, (might need) a custom drive shaft for supra not sure but needed it for the 300zx, might need to convert some wires.
The ecu should work fine with the manual tranny. These are only from the top of my head. Hope it helps :P
dunewarz is offline   Reply With Quote
