Old 05-03-2009, 09:49 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by bennybiggs View Post
i didnt think of that. the one im looking at buying is a 1995 five speed. the engine im not sure of the year but it has an auto transmisson on it. should i look for a total new ecu? i got a buddy that works for a shop that builds supras and said whatever i needed he can get me. how much you think he will charge me for the ecu and wiring harness?
Yes, you'll need a new ecu (as I said above). An n/a ecu can not control a 2jz-gte.
Swapping the engine+harness isn't too hard
...Among other things, you'll need a TT ecu, an ignitor, possibly an injector resistor pack, a different maf (I believe), and a new downpipe...
Used TT ecus usually go for about $200 last time I checked. A brand-new harness from 'yota is about $800 or so. Honestly I wouldn't try to make a second-hand harness work - they're usually full of broken plastic connectors and sometimes other continuity problems. Just mho.
Life begins at 30psi.
