Old 04-30-2009, 02:34 AM   #1
SideWinderGX
SideWinderGX is on a distinguished road
That little L shaped fitting leads to one of the power steering lines, there is two.
Stand over the passenger front fender and look straight down past the power steering resorvoir, about a foot and a half below it. There should be two fittings down there with two hoses coming off of it. The one closest to you should hook up to the fitting underneath the intake, if there is a hose on there at all.
If it is just a regular rubber hose you could try going to advanced auto parts or auto zone and finding a similar shaped/diameter hose and cutting it to length...each hose is maybe 5 dollars and it'll work just fine.
my car:
1987 brownish Toyota Supra Turbo, automatic 7MGTE engine with ~100k miles on it.
SideWinderGX is offline   Reply With Quote
