Thread: Low Compression
Old 04-29-2009, 11:30 AM   #1
Makz
Makz is on a distinguished road
Don't worry yet. It's not necessary to replace engine. Probably, change of piston rings will help. If the cylinder is bad, you'll need to bore engine block and replace pistons+rings on o/s 0,5mm
ex '87 MA70 7M-GTE, A/T, targa, rhd
ex '87 GA70 1G-GTE, M/T, targa,rhd
now '90 JZA70, 1JZ-GTE(swap), M/T, targa, lhd
18 inch PIAA Rozza wheels, HKS blow-off, Apexi turbotimer, XTD stage 3 racing clutch, AEM air filter, JZA80 fuel pump, 4-piston Skyline GT-R front brakes, Blitz boost-controller, high performance exhoust system
Makz is offline   Reply With Quote
