Thread: 400hp?
Old 04-22-2009, 04:00 AM   #1
Vacationtime247
Well, you could up the boost, get bigger injectors, bigger throttle body, change the wastegate, buy a clutch, rebuild the engine (if you don't, you'll soon be changing the head gasket), fix the shut off control on the fuel pump, get bigger exhaust and get an intercooler. You'll have all kinds of fun working on it too. Tight cramped spaces, taking off everything and remembering where it goes. It'd be great.
OR....You could build a 350 Chevy Engine for about the same price (or less) and drop it down in there. You'd make gobs of torque for tire shredding fun and it would be simple to work on. There is plenty of room for everything to clear and you wouldn't have any of the headaches.
VT247
Originally Posted by RedSupra87 View Post
I want around 400 hp. Can I achieve this with stock internals and if so how long will it hold up?Any 400 hp. set-up suggestions?
