Old 04-22-2009, 03:56 AM   #1
azerty
azerty's Avatar
azerty is on a distinguished road
Unhappy
I have tryed before to play with this boost controller, and I got till 17-18 PSI before hitting fuel cut.
Now, I have the Lexus AFM upgrade and upgraded injectors, and I tryed to raise boost again.
I tryed with the boost controller fully closed, and it raised no more then 13 PSI, with it fully opened I achived even lower boost.
I have to mention that when raising to 18 PSI,I didn`t hit the fuel cut, it just don`t raise higher.
And I understand that the stock CT26 is able of far more boost than that, am I wrong?
I will try to change some more hoses, just in case, but I sure would like to know if indeed the stock CT26 can make more boost, and how much?
If I disconect the vacuum hose that goes from the turbo, trough the boost controller to the wastegate, I get the same result of 13 PSI.
Don`t you think that it should have raised and raised....?
1988 yelow manual turbo targa
HKS ssqv bov
Hose Techniques silicon hoses
Forge manual boost controller
boost gauge
K&N FIPK
ACT clutch kit HD-G6
Fidanza lightened flyweel
550cc RC Injectors
255lph Walbro Fuel Pump
LIPP Lexus AFM Replica
3" turbo back echaust with divorced
downpipe and no cats.
Aeromotive FPR
Aem Uego Wideband Gauge+O2 sensor
azerty is offline   Reply With Quote
