Old 04-21-2009, 07:45 PM   #1
Mahonri
Mahonri is on a distinguished road
Sounds like it could be a number of things going wrong. First I would look into your boost controller, make sure its setup right with the ECU.
To answer your other question, I would go as far as 15 lbs PSI max on the stock CT26 turbo. Anything more then that and you get into problems.
Mahonri is offline   Reply With Quote
