7mgte Help???
Hey I'm new to the whole Supra thing but I have bought myself one for 900 and was woundering what could be wrong with it... I have checked the timing because it has a bad side to it. It loves to shut off after u stop. I went and got myself a hanes manual for it and started pulling it apart and when I checked I had oil were the spark plug wires sit so I know what to fix there but I pulled the timing light out and start the car and 1) The light doesn't flash unless I rev the motor, 2) I changed the AFM because I was told it had the sc400 AFM on it but the Injectors were stock. but know when the light on the timing gun actually flashes it shows me like 45deg of TDC So I pulled everything and but it all At TDC and It continues to do the same and mind you this is with connector Jumped as the manuel stats to do... So what now alittle help please the car just doesn't feel right and has a nasty studer about the Idle... Also I have noticed that my boost is higher than stock. My factory gauge read over 8psi.. Thanks for the help...
