Upgrade advice needed
So this is what I have started on. I've got the engine down to the block. Head and everything else off, an I am getting ready to pull the engine to do the clutch and flywheel. I also figured I'd check my rear main while I was at it and change out my oil pan gasket. I already have most of the parts listed below but am I missing anything. I do have new rims, electric cut-out, lightweight driveshaft, and possibly an EGT gauge in the future but I put those on hold for now. I also replaced the power steering pump, belts - including timing, spark plugs, numerous gaskets and seals, coolant hoses, vacuum lines, ICV, battery, lower ball joints, and tie rods.
-60-1 upgraded turbo
-Lexus AFM
-hi-flow air filter
-3" exhaust, 4" tip
-SAFC 2
-walbro 255LPH fuel pump
-550cc injectors
-2.5" intercooler and piping
-aluminum radiator
-ARP studs w/MHG
-Lightweight aluminum flywheel
-Stage 3 clutch
-Electronic Boost Controller
-Full-auto turbo timer
-A/F guage
-Boost gauge
-Aeromatic fuel pressure regulator
-Electric fans
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
