Old 04-10-2009, 04:58 AM   #1
Quint
Quint is on a distinguished road
I've never understood why people say they are hard to get off, they are a piece of piss.
Lay on your back under the car with your head under the sump and your legs down the length of the drive shaft. reach your left hand around the top of the bellhousing (between the firewall and block) and feel the bolts, they are 12mm from memory (might be 14) pass a spanner up with ur right hand to ur left hand, put it on the bolt using ur left hand, hold it there while you pull on the spanner with ur right hand, easy.
Failing this, lay on the rocker covers and reach down to the start motor, two bolts, thats it.
Quint is offline   Reply With Quote
