Old 08-10-2005, 03:41 AM   #1
Poodles
Poodles is on a distinguished road
aye, mine just went out and took the hydraulic system with it, $900 to repair, and I just bought the thing. Guy said it had a new clutch, he lied, so I'm ticked...
Clutch system is very simple, being a clutch cover and a clutch plate with the flywheel. The clutch is sandwiched between the 2 and put under pressure through the clutch cover spring. The hydraulic system only releases the spring. If the spring, or the actualy clutch are warn out, you'll slip. Also, if you get mud, water, grease, oil, ect up into that area, you can also have a problem.
Poodles is offline   Reply With Quote
