Old 04-02-2009, 03:41 AM   #2
Vacationtime247
Default Hope I'm helping.....
What sensor tells the computer when to give the coils a signal on the motor you have installed? Is it a cam position sensor? A Crank sensor? Check for proper voltage out at that location with the engine turning over. Another thought is to make sure you have all your grounds. Computers and sensors don't act right without a good ground.
VT247
