Old 03-23-2009, 10:22 PM   #2
mkIII supra turbo gav
mkIII supra turbo gav's Avatar
mkIII supra turbo gav is on a distinguished road
Originally Posted by Bill UK View Post
You may still may have a problem with that in the summer, when you select the cold setting on the heater control; this operates a control valve on the bulkhead. (near the ABS unit on UK models) this shuts off any coolant going into the heater matrix. The coolant is then diverted back around the system from the pipe union at the rear of the head, which is the same as the heater matrix becoming blocked.
i also changed the water pump which was leaking too
mkIII supra turbo gav is offline   Reply With Quote
