Old 03-23-2009, 09:23 PM   #1
Bill UK
AEM EMS
Bill UK's Avatar
Nothing, your need to unplug the AC fans. I can’t remember if there’s enough room to pull the rad out with the fans fixed to the rad. If it were an auto box then you would need to disconnect the feed and return hoses at the bottom of the rad. The radiator sits on two rubber cushions, sometimes the rubber sticks to the mounting bracket & rad, you may need to give it a gentle tug. Take care not to hit the large cooling fan blades.
