Old 03-19-2009, 07:36 AM   #1
jhealey1967
jhealey1967 is on a distinguished road
Thanks for the info Quint, I really appreciate it. The website is helpful as well.
Do you know if a gearbox from a 2wd truck would work, like a 2wd Hilux/Tacoma?
Do you know if the Cressida is the only car that had the short 18" shifter to bellhousing spacing?
I'm running a Fidanza flywheel made for the Jag. I imagine I'll just have to have the Toyota pressure plate re-drilled by my local machine shop to match up to the studs and bolt holes on the Fidanza flywheel. Hopefully it isn't any more complex than that.
jhealey1967 is offline   Reply With Quote
