Old 02-23-2009, 12:31 AM   #1
btwilson86
Super Moderator
btwilson86's Avatar
I'd agree. If the damage to an existing engine can be fixed with a rebuild, then it should be rebuilt. I swapped in a JDM 7MGE into my old 87, but that was only because I had two golf ball sized holes in the block of the blown enigine (can't exactly rebuild that, haha).
BTW, what was the reason that the "local Supra guy" gave you for not buying JDM? Most different parts can usually be swapped over from your current motor, so I'm kind of curious what his reason's are...
Oh, and be sure you check out the shop you take the motor to before you get that rebuild. Ask them if they've even seen one of these motors before, as alot of mechanics assume they know what they're doing and f*** something up in the rebuild. If you're doing it yourself, do some research and ask quiestions if you need to know.
