Thread: Oil pan leaking
Old 02-13-2009, 04:51 PM   #1
gottadiesel
gottadiesel's Avatar
gottadiesel is on a distinguished road
Try to get it clean enough to tell 1st and trying to get it to leak when not moving as it blows around etc...
I found an intake @ cxlightning ebay store, but must be for a T4, it required a 4" inlet.
I will keep looking, I prefer not to got with OEM if I can find something with better aerodynamics if you will through the air path.
I am in Winlock, between Portland and Seattle. My Dad and a niece and some other relatives are over there in the Tri-Cities area... if I get over there later with my car, I'd love to take a look at yours.
So no ECM that you can control fuel flows are anything, I have been working with the VW TDI motors and it utilizes a software package, so it will only throw error codes is what you are saying. In that case I have no dummy lights on.
From my earlier post, have you have expereince with the oem oil pressure gauge being inaccurate? I am a little leary about doing too much till I verify oil pressure, but then several of the little items I need to replace, would be perfect to do when I am getting to the port for oil pressure any, as it appears I need to remove several items off that side fo the motor to get to it... when @ operating temp I am running 4 or 5 at idle 18-20 @ 2.5 to 3k and it might go up to 25 @ 3.5 or 4k....
Any thoughts would be appreciated - Thanks Charles
oh yeah, not positive, odometer reads 124k, but speedo cable is broken, not sure how long somewhere drove without it, I have a new one to install.
New Supra Owner, 1988 5spd Turbo, minimal mods - Black Stagger Wheels Rear 225/45/18 on 18x8, Front 215/40/17 on 17x7.5. Aluminum cooler to TB pipe with SQV BOV, SS Turbo Intake with HV MAF Filter Adp.
Tunes - Kenwood Deck Driving Kenwood 1200W 2CH / Sony 1000W 2CH, Kenwood 750W Class D Mono, Rockford Fosgate 500W Mono. Amps Driving (4) 4.5 140w, (2) 6.25 200w, (2) 6x9 225w, (2) JL 10's and (1) JL 8... Yea its loud enough
gottadiesel is offline   Reply With Quote
