Old 01-23-2009, 08:16 PM   #2
carnahkt
carnahkt is on a distinguished road
I am using dexron III. I am bleeding it by turning the wheel lock to lock engine off. When I bleed it the level should drop but it is actually rising and I tried taking some out and starting it up real quick but it still whined as if there is air in the lines. What is even wierder is that when I took the pump off and then back on it seemed to bleed ok and work fine for about 5 min then it foamed up and started whining again and now I have the same problem bleeding it again, so it is seems that the problem is intermitent.
carnahkt is offline   Reply With Quote
