Old 01-23-2009, 07:10 PM   #1
CyFi6
First off are you using ATF Dexron III? If not, you need to be. Second after you start the car are you bleeding it by turning the wheels lock to lock? If its overflowing when you do this take some fluid out of the reservoir. If it still keeps pushing too much fluid up its possible there is a problem in the steering rack/control valve etc.
