Thread
Testing a Knock Sensor
01-17-2009, 07:28 AM
2
jrok
in the car
at 2000 rpm hit the intake the timing should change or to bench test when you strike it it should produce some electricty but very small....problem usually in the wiring, check wire to ground, the outside of the wire should be grounded.
1984 celica supra with 7mgte swap, custom intercooler, 2.5 exhaust no muffler or cat, shimmed wastegate to 12 lbs boost, with r154 turbo 5-speed tranny 16x8 xxr s13's with 245/50R16 toyo proxes 4's
http://au.youtube.com/watch?v=rgOxP0PxCwo
http://au.youtube.com/watch?v=uf989mb3EDw
also own:
2000 4runner 3 inch lift, 33inch tires
http://au.youtube.com/watch?v=J15k1rCh7-A
1988 4runner stock
http://au.youtube.com/watch?v=2u7e1_pMqfs
http://au.youtube.com/watch?v=9lu4j5P6M7M
jrok
View Public Profile
Send a private message to jrok
Find More Posts by jrok
