Old 01-16-2009, 05:21 AM   #2
rj_conerly
rj_conerly is on a distinguished road
Default Fuel Pump went out?
i got a n/a and i'm still dealing with the same problem try bridging the teminals B+ and FP and check your pressure if its normal then you need to check your relays i know i have to change my fuel pump relay and efi main relay. and on top of that if could be as easy as a clogged fuel filter. i got all of those parts at auto zone the efi main relay and the fuel filter were 20 eacha dn the fuel pump relay was like 60 or 70. so choose your posion. if you bridge the terminals and you still don't have pressure then its you're fuel filter. if it's one of your relays there are places that can check them for you. good luck hopefully your fix is cheaper than mine.
rj_conerly is offline   Reply With Quote
