Old 12-20-2008, 04:57 AM   #1
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
Originally Posted by mrnickleye View Post
I by-passed the throttlebody coolant lines years ago. Just use a metal or plastic connector to hook both hoses together. Then get a couple of large vacuum caps and put onto the TB fittings (looks better, and keeps dirt out).
I recommend doing this to everyone. The ONLY reason coolant is run thru the TB is to warm it up sooner for a little more emmisions control. BUT......The cooler the air going into the engine, the better it runs, and more HPs.
Too true, I remember when you told me to do this a couple years back, havent had a problem since :-)
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
