Old 12-17-2008, 07:26 PM   #1
dieseltech24179
dieseltech24179 is on a distinguished road
Default Timing
Alright ill check it again to make sure. My timing light doesn't have a dial it just has a red button?? This could be like a reset button to calibrate the strobe to the spark. I also had two more engine codes pop up to. The first two I had was just the AFM code and throttle pos sensor code (51 I think). Now I have the knock sensor code and code 14 the ignitor code. But wouldn't my car not start at all if the ignitor was bad? I just put one on it from ebay cuz the old one was torn apart. Also before I set the timing I had intermittant starting problems and when it finally decided to start I checked/set the ign timing. Now it has started everytime after that but I've got those two codes and it won't boost over 3psi.
dieseltech24179 is offline   Reply With Quote
