Old 12-14-2008, 03:15 AM   #1
Chambers
Chambers's Avatar
The MAFT Pro, in other words, the top of the line, hehehe, uses a GM MAP sensor, which will replace your MAF sensor. I believe the lower end MAFT translators do the same but I don't know much about them. It is a great tool, and will allow you to tune your fuel maps. The only thing is it may require some tuning to get it on track. I'm planning on picking up a MAFT Pro system to run on my NA. There is a lot of info on it at supramania.com.
Good luck.
"Stuck in the 80's"
