Old 12-10-2008, 03:57 PM   #1
Boombastic
Boombastic is on a distinguished road
Agreed, for the most part. Ideally the best way to get the correct offset is to purchase the rims manufactured with the correct offset in the first place (i.e. not with a spacer, if at all possible).
I also agree that the best way to get the broken stud base out is with a press. You can try to hammer it out, but be forewarned that you'd likely damage the wheel bearing by doing it that way. The wheel bearing isn't designed to take that type of lateral hammering force.
Yea I know about the offset and spacer thing, I dont do that but I have seen it done and was like wow, your going to die!
Boombastic is offline   Reply With Quote
