Old 08-04-2005, 06:49 AM   #1
Poodles
Poodles is on a distinguished road
Clutch system could be low, check the fluid. If there is air in it, it will need to be bled. Spring on the peddle could be broken. Throw out bearing could be sticking, flex plate could be extremely warn, ect, ect. If it's not the fluid or spring, get it looked at by a shop, as if you don't have a lift, it's going to be a pain to drop the tranny and check the clutch system...
Poodles is offline   Reply With Quote
