Old 11-30-2008, 10:45 PM   #1
ddouglas77
ddouglas77 is on a distinguished road
Originally Posted by Chambers View Post
The best way would be jack it up and put jack stands in the correct places on either side of the car. After that I think you will need a few large wrenches, I think anywhere between 17mm and 21mm, I can't remember exactly. Also a 10mm socket to remove a bracket for the lines.
If you got the hose from Driftmotion, then you will have to wrestle it a little to get it to work, but I will fit fine, may be good to have a friend help.
Also make sure to refill the reservoir with Dextron II or III auto tranny fluid when finished.
Good luck.
Yes, it is from driftmotion. Mobil 1 ATF fluid OK to use?
Light moves faster than sound. That is why some appear to be bright, until you hear them speak.
1987 Toyota Supra Turbo, 1990 Alfa Romeo Spider, 1974 Chevy Camaro.
ddouglas77 is offline   Reply With Quote
