Old 11-30-2008, 10:43 PM   #1
Chambers
Chambers's Avatar
The best way would be jack it up and put jack stands in the correct places on either side of the car. After that I think you will need a few large wrenches, I think anywhere between 17mm and 21mm, I can't remember exactly. Also a 10mm socket to remove a bracket for the lines.
If you got the hose from Driftmotion, then you will have to wrestle it a little to get it to work, but I will fit fine, may be good to have a friend help.
Also make sure to refill the reservoir with Dextron II or III auto tranny fluid when finished.
Good luck.
"Stuck in the 80's"
