Old 11-30-2008, 07:16 PM   #1
Chambers
Chambers's Avatar
I usually put about 5 quarts in my NA, so a GTE will take a little more. The oil level is hard to see on the cable type, when you pull the dip stick out, lay it on a paper towel. That way you can see how far up the oil level is.
Hope this helps, good luck.
"Stuck in the 80's"
