Old 11-29-2008, 08:09 PM   #3
Chambers
Chambers's Avatar
Don't unbolt the tensioner, just loosen it. Then you can use plyers to remove the spring that holds tension on the belt. After that just do as stated above, set all the marks to the correct place.
Good luck.
"Stuck in the 80's"
