Old 11-29-2008, 08:00 AM   #1
CyFi6
You need to loosen the timing belt tensioner and slide the belt off the cams, then put the crank to the 0 mark, turn the cams so they are strait up and put the belt back on, and re-tension. Make sure you torque the tensioner bolt to the proper specs!! If you over tighten it you can cause the #1 cylinder to change shape and cause excessive blowby
